Ajax wrote:I feel like the shallow, fresher waters of my cove don't retain heat that is seen at the bay data buoys. When it gets cold, the cove sheds heat much faster.
Tucky wrote:We got our first snow of the season yesterday- 6 " or so. About time. When I read about you folks out west where snow is unusual I always start to sing Van Morrison's "Snow in San Anselmo".
"My waitress, my WAITRESS said it was coming down"
kimbottles wrote:29F THIS MORNING!!
We have several CA/Scantlingers coming over to use our mooring buoys today. Maybe 5-7 boats in total. I will post a picture of the now traditional Blakely Harbor New Years Eve raft up..........if I remember.
Nice sun here today even if it is a bit nippy out!
BeauV wrote:kimbottles wrote:29F THIS MORNING!!
I wish we could join you. It got to 33°F here last night - which is freeeeking cold for Santa Cruz!!
Panope wrote:Kim, as you experienced when we tested your anchors, keeping the interior heated is THE way to go during winter boating. Even when on deck for most of an outing, the occasional 'warm up' down below is just what one needs to stay happy.
Even if I am just at the dock for some chores, I fire up that heat every time.
If I were you I would drop EVERYTHING else and focus on the Wallace heater install.
Steve
kimbottles wrote:Panope wrote:Kim, as you experienced when we tested your anchors, keeping the interior heated is THE way to go during winter boating. Even when on deck for most of an outing, the occasional 'warm up' down below is just what one needs to stay happy.
Steve
Well we actually have a little portable Origo space heater called a "Heat Pal" we can use, but the Wallas project is on the front burner. The Origo is alcohol so put out moisture whereas the Waalas is diesel and creates drying heat.
BeauV wrote:Be sure to check the maximum allowable run for the exhaust pipe.... don't ask me how I know about this....
kimbottles wrote:OK, I spent some time mapping out the duct paths and came to the conclusion it would be way easier to just move the furnace!
Why did I have the crew put it way back under the tiller when there is plenty enough room on the starboard side of the engine room only three feet from the heater outlets??
Dumb!!
So now I will get to work on relocating it where I should have had them put it all along!
Dumb!!
