Who bent the trees?
Moderator: SoƱadora
Who bent the trees?
Postby Orestes Munn » Fri Mar 31, 2017 8:29 am
Orestes Munn
Re: Who bent the trees?
Postby JoeP » Fri Mar 31, 2017 1:42 pm
My first thought was shipbuilders but since the species of tree was not mentioned it's hard to say for sure. Could've been alien shipbuiders though.
Postby LarryHoward » Fri Mar 31, 2017 1:55 pm
Same guys that broke your drive leg. Aliens.
Postby kimbottles » Fri Mar 31, 2017 3:06 pm
We actually have a grove like that up at the north end of Bainbridge Island. I believe it is earth movement (land slide) and then the trees start reaching to the sun again.....but the snow load argument sounds like a possibility too. The trees got bent over and then continued to grow......up.
Postby BeauV » Fri Mar 31, 2017 5:38 pm
Kim, I don't think your theory works on flat ground. I've got another theory, someone cut those trees down and left the stumps. The stumps sent out sprouts from the stump and those turned upward towards the sun. Redwood stumps send up multiple shoots once a tree is cut down. They form what my grandchildren call "fairy rings". See below.
Postby kimbottles » Fri Mar 31, 2017 10:38 pm
BeauV wrote:Kim, I don't think your theory works on flat ground. I've got another theory, someone cut those trees down and left the stumps. The stumps sent out sprouts from the stump and those turned upward towards the sun. Redwood stumps send up multiple shoots once a tree is cut down. They form what my grandchildren call "fairy rings". See below.
You live in California and don't know about earthquake land shift????
Postby Olaf Hart » Sat Apr 01, 2017 6:34 am
Postby kimbottles » Sat Apr 01, 2017 11:25 am
Yeah! I am pretty worried about today.
I have both Anomaly and FastYacht from CA visiting. At the same time. This could be trouble!
Postby Anomaly » Sat Apr 01, 2017 12:39 pm
How could I pass this up: Fast told me that you're going to let us practice docking under sail with Frankie at Pier 60 while you run some errands.
Anomaly
