Tricks of the trade
Tricks of the trade
Postby Olaf Hart » Fri Jan 10, 2020 6:45 pm
Just thought I would share this...
Last year I was given an Ampair wind generator, it had been around the world and worked fine, but the support bearings were on the way out, so it rattled and whined.
I sourced a bearing repair kit in Singapore, so thought I would try to repair it, don’t have any plans to use it but I am always a sucker for a project and like recycling old stuff.
So the support bearings and slip contacts came out reasonably easily, but I was left with a blind bearing at the top of the support tube that was frozen in, steel in aluminium, that sort of thing.
Tried heat and cold, modified a bearing puller so it fit the small 1/2 inch center and tried that, no go.
Thanks to Utube, I found out about wet toilet paper, the trick is to drive it into the center of the bearing and it gradually forces the whole thing out of the blind socket.
I ground down the head of a bolt so it was a snug fit in the 1/2” bearing center hole, packed in wet toilet paper and drove it in with the bolt, had to repack it around a half dozen times.
Worked like a charm, drove the bearing out and left behind a donut of packed wet toilet paper....
Some people also talk about grease working, but the paper seems cleaner.
Re: Tricks of the trade
Postby Ken Heaton (Salazar) » Fri Jan 10, 2020 8:41 pm
Here's an example, using bread the same way: https://www.youtube.com/watch?v=00OlG5E8vLk
S/V Salazar - Can 54955 - C&C 37/40 XL - Hull # 67
Cape Breton Island, Nova Scotia, Canada
https://c-c-37-40.blogspot.ca/p/salazar.html - http://www.cruising-cape-breton.info/
Location: Sydney, Cape Breton Island, Nova Scotia, Canada
Postby TheOffice » Tue Jan 14, 2020 11:16 am
Love it!!
Thanks for the cool tip!
Postby BeauV » Wed Jan 15, 2020 11:23 am
That is a GREAT technique!! Thanks!
Postby H B » Tue Jan 21, 2020 10:25 am
Whoa..nice! :like:
