Hey everyone,
Hard to google for, no results so far other than "bucket" and "expensive"...
Long story short, my house has a "tankless" hot water system, and it takes a really long time to get hot water to the shower or sink. Newport is technically on an island, so besides being straight-up wasteful, our water is very expensive. 4 people use about 4500 gallons a month here, and that costs around $200.
We currently conserve water by capturing the water that we run-off waiting for it to get hot in a bucket, and then flush the toilet by dumping it in the bowl. The solution is far from ideal. In particular, during a tank-flush, you end up with a bowl full of clean water. With the bucket-flush, usually we end up with a close-to-empty bowl of still-kinda-dirty water. Smaller issues are that it's easy to spill, and gee it sure is a luxury to just press the lever instead of having a project to deal with before you're done with your business.
I'm wondering if there are any simple/inexpensive systems out there that let you dump that water into an auxiliary reservoir connected to a toilet's tank at prior point, and then that will (primarily) fill the tank rather than fresh water after a flush? I'm visualizing something using large-bore siphons that race to fill the tank with grey water before more than a fraction of it is filled from the clean water supply - thus there's no risk of over-filling, and it doesn't need power or a motor. But I'm open to alternatives.
