The oil and filter on my boat were changed last fall. Since then, I've powered far enough to burn approx 5 gallons of diesel out of my 20 gallon tank. I usually change the oil and filter every fall, and I understand about oil "going bad" with time as well as with use. But....
Do I have to change filter this fall? On the one had, it's had very little use; on the other hand, it does hold a non-trivial amount of oil. What say you?
